旧 2008-12-14, 20:05   #1
xiangrufeia
注册日期: 2008-10-08
年龄: 40
xiangrufeia 正向着好的方向发展
默认 [求助]如何取一段高频信号的包络啊
function smf = matchedfilter(s,r,fs)
% MATCHEDFILTER calculates the matched filter output
% of signal s with replica r.
% smf = matchedfilter(s,r,fs)
% input:
% s : the signal
% r : the replica
% fs : the sample frequency
% output:
% smf : the matchedfilter output
ls = size(s);
if (ls(1) ~= 1),
s = s';
ls = max(ls);
r(r==0) = [];
lr = size(r);
if (lr(1) ~= 1),
r = r';
lr = max(lr);
T = lr/fs;
if (ls < lr),
error('Replica must have smaller length than signal');
% Normalize replica on energy 1
%r = r/sqrt(r*r');
% Normalize replica on maximum amplitude 1
r = r/abs(max(r));
% determine number of points in fft
p = 2^ceil(log(ls)/log(2));
if p==ls, % remove wrap around effects when
p=2*p; % signal is already 2^n in length
% correlation by multiplication in frequency domain
y = conj(fft(r,p)).*fft(s,p);
% perform Hilbert transform (stolen from hilbert.m)
% throw away negative frequencies and double positive frequencies
if p ~= 1
% freq>0 Nyquest freq<0
h = [1; 2*ones(fix((p-1)/2),1); ones(1-rem(p,2),1); zeros(fix((p-1)/2),1)];
y( = y(.*h;
% matched filtered output
smf = abs(ifft(y))'; % envelope这个应该是取包络的意思,可是我不太明白,请高手指教啊%smf1 = real(ifft(y)'); % real part
%smf2 = imag(ifft(y)'); % imaginery part
smf(ls+1) = []; % adjust the output to same length as input signal
smf = smf*2/T/fs; % normalization according to amplitude signal
%figure;
%plot(smf);
% end
xiangrufeia 当前离线   回复时引用此帖
matlab工具箱函数汇总(很全) chenjinyang MATLAB论坛 17 2011-02-27 21:13
[求助]这个积分需要加点什么条件能够得到合理的结果 风雨浪涛 MATLAB论坛 4 2009-04-01 22:39
[求助]sim函数 神经网络仿真的问题 jitter MATLAB论坛 0 2009-03-22 15:59
[讨论]哥德巴赫猜想-张俊龙的“0+0”全新的数学成果之4-《间接的个数“0+0”在直观条件下成立的奥妙》 龙舞山威 数学 0 2008-04-01 16:05
所有时间均为北京时间。现在的时间是 09:09
