旧 2007-12-11, 16:14   #1
yesman
yesman 的头像
注册日期: 2007-04-05
声望力: 28
默认 【文章】仿真设计作品--蹦球
figure(1);%定义函数
axis([-5.1,5,-0.05,1.05]);%绘制二维图形
hold on;%保持当前图形及轴系所有的特性
axis('off');%覆盖坐标刻度,并填充背景
%通过填充绘出台阶及两边的挡板
fill([-5.1,-5,-5,-5.1],[-0.05,-0.05,1.05,1.05],[0,0.5,0]);
fill([4.12,4.22,4.22,4.12],[-0.05,-0.05,1.05,1.05],[0,0.5,0]);
fill([-5,-3.2,-3.2,-5],[-0.05,-0.05,0,0],[0,0.5,0]);
fill([-3.2,-2.8,-2.8,-3.2],[-0.05,-0.05,0.2,0.2],[0,0.5,0]);
fill([-3.2,-1.4,-1.4,-3.2],[0.2,0.2,0.25,0.25],[0,0.5,0]);
fill([-1.4,-1,-1,-1.4],[0.2,0.2,0.45,0.45],[0,0.5,0]);
fill([-1.4,0.4,0.4,-1.4],[0.45,0.45,0.5,0.5],[0,0.5,0]);
fill([0.4,0.8,0.8,0.4],[0.45,0.45,0.7,0.7],[0,0.5,0]);
fill([0.4,2.0,2.0,0.4],[0.7,0.7,0.75,0.75],[0,0.5,0]);
fill([2.0,2.3,2.3,2.0],[-0.05,-0.05,0.75,0.75],[0,0.5,0]);
fill([2.3,4.12,4.12,2.3],[-0.05,-0.05,0,0],[0,0.5,0]);
%x1=line([-5,5],[0,0],'color','g','linestyle','-', 'markersize',50)%设置台阶边框线,颜色,擦试方式
%x2=line([-5,5],[0.25,0.25],'color','g','linestyle','-', 'markersize',50)%设置台阶边框线,颜色,擦试方式
%line([-5,5],[0.5,0.5],'color','b','linestyle','-', 'markersize',50)%设置球与地面接触面的颜色,擦试方式
%line([-5,5],[0.75,0.75],'color','b','linestyle','-', 'markersize',50)%设置球与地面接触面的颜色,擦试方式
head=line(-5,1,'color','r','linestyle','.','erasemode','xor', 'markersize',60);%设置小球颜色,大小,线条和擦试方式
%body=line(-5,1,'color','b','linestyle','-','erasemode','none'); %描绘轨迹线
%设置初始条件
t=-5;
dt=0.001;
w=0;
dw=0.001;
while 1 %设置球跳到第一台阶的范围和高度
while t<=-4
t=dt+t;
if w<=1
w=dw+w;
else
w=-1;
y=-w*w+1;
set(head,'xdata',t,'ydata',y);%设置球的运动
%set(body,'xdata',t,'ydata',y);%描绘轨迹线
drawnow;
end %结束程序
w=-1;%设置球弹起的初始位置
%设置球跳到第二台阶的范围和高度
while t<=-2.31
t=dt+t;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/2+0.5;
drawnow;
end %结束程序
w=-1;%设置球弹起的初始位置
%设置球跳到第三台阶的范围和高度
while t<=-0.62
t=dt+t;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/2+0.75;
drawnow;
end %结束程序
w=-1;%设置球弹起的初始位置
%设置球跳到第四台阶的范围和高度
while t<=1.1
t=dt+t;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/2+1;
drawnow;
end %结束程序
w=-1;%设置球弹起的初始位置
%设置球跳到第五台阶的范围和高度
while t<=2.11
t=dt+t;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/4+1;
drawnow;
end %结束程序
w=0;%设置球弹起的初始位置
%设置球弹起的高度
while t<=4.12
t=dt+t;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)+1;
drawnow;
end %结束程序
w=0;%设置球弹起的初始位置
%设置球弹起的高度
while t>=2.11
t=t-dt;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)+1;
drawnow;
end %结束程序
w=0;%设置球弹起的初始位置
%设置球弹起的高度
while t>=1.11
t=t-dt;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/4+1;
drawnow;
end %结束程序
w=-0.71;%设置球弹起的初始位置
%设置球弹起的高度
while t>=-0.62
t=t-dt;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/2+1;
drawnow;
end %结束程序
w=-0.71;%设置球弹起的初始位置
%设置球弹起的高度
while t>=-2.31
t=t-dt;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/2+0.75;
drawnow;
end %结束程序
w=-0.71;%设置球弹起的初始位置
%设置球弹起的高度
while t>=-4
t=t-dt;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)/2+0.5;
drawnow;
end %结束程序
w=-1;%设置球弹起的初始位置
%设置球弹起的高度
while t>=-5
t=t-dt;
if w<=1
w=dw+w;
else
w=-1;
y=(-w*w)+1;
drawnow;
end %结束程序
2005年10月31日发表在《麓瑜园》
(注:本文转自转自《麓瑜园》,版权归原作者所有!在此仅作交流讨论之用,如需转载请注明原作者!)
yesman 当前离线   回复时引用此帖
所有时间均为北京时间。现在的时间是 07:53
