#1 |
注册日期: 2009-03-24
声望力: 0 ![]() |
%**************************************求正负极大值对*****************************************%
ddw=zeros(size(swd)) pddw=ddw; nddw=ddw; %小波系数的大于0的点 posw=swd.*(swd>0); %斜率大于0 pdw=((posw(,1 points-1)-posw( ,2 points))<0); %正极大值点 pddw( ,2points-1)=((pdw( ,1points-2)-pdw(,2points-1))>0); %小波系数小于0的点 negw=swd.*(swd<0); ndw=((negw(,1points-1)-negw(,2points))>0); %负极大值点 nddw(,2points-1)=((ndw(,1 ![]() %或运算 ddw=pddw|nddw; ddw(,1)=1; ddw(,points)=1; %求出极值点的值,其他点置0 wpeak=ddw.*swd; wpeak(,1)=wpeak(,1)+1e-10; wpeak(,points)=wpeak(,points)+1e-10; %画出各尺度下极值点 figure; for i=1:level subplot(level,1,i); plot(wpeak(i,)) axis tight;grid on; ylabel(strcat('j= ',num2str(i))) end subplot(4,1,1); title('ECG信号在j=1,2,3,4尺度下的小波系数的模极大值点'); interva2=zeros(1,points); intervaqs=zeros(1,points); Mj1=wpeak(1,); Mj4=wpeak(3,); %画出尺度3极值点 figure; plot (Mj4); title('尺度3下小波系数的模极大值点'); posi=Mj4.*(Mj4>0); %求正极大值的平均 thposi=(max(posi(1:round(points/4)))+max(posi(round(points/4):2*round(points/4)))+max(posi(2*round(points/4):3*round(points/4)))+max(posi(3*round(points/4):4*round(points/4))))/4; posi=(posi>thposi/3); nega=Mj4.*(Mj4<0); %求负极大值的平均 thnega=(min(nega(1:round(points/4)))+min(nega(round(points/4):2*round(points/4)))+min(nega(2*round(points/4):3*round(points/4)))+min(nega(3*round(points/4):4*round(points/4))))/4; nega=-1*(nega<thnega/4); %找出非0点 interva=posi+nega; loca=find(interva); for i=1:length(loca)-1 if abs(loca(i)-loca(i+1))<80 diff(i)=interva(loca(i))-interva(loca(i+1)); else diff(i)=0; end end %找出极值对 loca2=find(diff==-2); %负极大值点 interva2(loca(loca2(1:length(loca2))))=interva(loca(loca2(1 length(loca2)))); %正极大值点 interva2(loca(loca2(1:length(loca2))+1))=interva(loca(loca2(1 length(loca2))+1)); intervaqs(1 ![]() count=zeros(1,1); count2=zeros(1,1); count3=zeros(1,1); mark1=0; mark2=0; mark3=0; i=1; j=1; Rnum=0; %*************************求正负极值对过零,即R波峰值,并检测出QRS波起点及终点*******************% while i<points if interva2(i)==-1 mark1=i; i=i+1; while(i<points&interva2(i)==0) i=i+1; end mark2=i; %求极大值对的过零点 mark3= round((abs(Mj4(mark2))*mark1+mark2*abs(Mj4(mark1)))/(abs(Mj4(mark2))+abs(Mj4(mark1)))); %R波极大值点 R_result(j)=mark3-10; count(mark3-10)=1; %求出QRS波起点 kqs=mark3-10; markq=0; while (kqs>1)&&( markq< 3) if Mj1(kqs)~=0 markq=markq+1; end kqs= kqs -1; end count2(kqs)=-1; %求出QRS波终点 kqs=mark3-10; marks=0; while (kqs<points)&&( marks<2) if Mj1(kqs)~=0 marks=marks+1; end kqs= kqs+1; end count3(kqs)=-1; i=i+60; j=j+1; Rnum=Rnum+1; end i=i+1; end %************************删除多检点,补偿漏检点**************************% num2=1; while(num2~=0) num2=0; %j=3,过零点 R=find(count); %过零点间隔 R_R=R(2:length(R))-R(1:length(R)-1); RRmean=mean(R_R); %当两个R波间隔小于0.4RRmean时,去掉值小的R波 for i=2:length(R) if (R(i)-R(i-1))<=0.4*RRmean num2=num2+1; if signal(R(i))>signal(R(i-1)) count(R(i-1))=0; else count(R(i))=0; end end end end num1=2; while(num1>0) num1=num1-1; R=find(count); R_R=R(2:length(R))-R(1:length(R)-1); RRmean=mean(R_R); %当发现R波间隔大于1.6RRmean时,减小阈值,在这一段检测R波 for i=2:length(R) if (R(i)-R(i-1))>1.6*RRmean Mjadjust=wpeak(4,R(i-1)+80:R(i)-80); points2=(R(i)-80)-(R(i-1)+80)+1; %求正极大值点 adjustposi=Mjadjust.*(Mjadjust>0); adjustposi=(adjustposi>thposi/4); %求负极大值点 adjustnega=Mjadjust.*(Mjadjust<0); adjustnega=-1*(adjustnega<thnega/5); %或运算 interva4=adjustposi+adjustnega; %找出非0点 loca3=find(interva4); diff2=interva4(loca3(1:length(loca3)-1))-interva4(loca3(2:length(loca3))); %如果有极大值对,找出极大值对 loca4=find(diff2==-2); interva3=zeros(points2,1)'; for j=1:length(loca4) interva3(loca3(loca4(j)))=interva4(loca3(loca4(j))); interva3(loca3(loca4(j)+1))=interva4(loca3(loca4(j)+1)); end mark4=0; mark5=0; mark6=0; while j<points2 if interva3(j)==-1; mark4=j; j=j+1; while(j<points2&interva3(j)==0) j=j+1; end mark5=j; %求过零点 mark6= round((abs(Mjadjust(mark5))*mark4+mark5*abs(Mjadjust(mark4)))/(abs(Mjadjust(mark5))+abs(Mjadjust(mark4)))); count(R(i-1)+80+mark6-10)=1; j=j+60; end j=j+1; end end end end %画出原图及标出检测结果 figure; plot(ecgdata(0*4096+1:1*4096)),grid on,axis tight,axis([1,points,-2,5]); title('ECG信号的R波峰值及QRS波波段'); hold on plot(count,'r'); plot(count2,'k'); plot(count3,'k'); for i=1:Rnum if R_result(i)==0; break end plot(R_result(i),ecgdata(R_result(i)),'bo','MarkerSize',10,'MarkerEdgeColor','g'); end hold off |
