旧 2009-05-05, 13:14   #1
olivetianqin
注册日期: 2009-04-21
olivetianqin 正向着好的方向发展
默认 急请教:正态分布曲线拟合问题
大家好,有个问题请教一下:有h,mu两组数据,以h为横坐标,mu为纵坐标,做出来的图形有点类似于正态分布,但不是,希望可以用一个正态分布,来拟合它,失真一点没关系,有些点也可以外加处理,主要是希望得到个正态分布的拟合,强调下失真点没关系,对于h在-10——10之间的数据可以根据正态分布的需要进行处理,请问该怎么解决呢?谢谢!
数据如下:
h=[-9000,-8000,-7000,-6000,-5000,-4000,-3000,-2000,-1100,-1000,-900,-800,-700,-600,-500,-400,-300,-250,-200,-160,-140,-120,-100,-90,-80,-70,-60,-46,-36,-30,-25,-20,-17,-15,-13,-11,-10,-9,-8,-7,-6.30000000000000,0,6.30000000000000,7,8,9,10,11,13,15,17,20,25,30,36,46,60,70,80,90,100,120,140,160,200,250,300,400,500,600,700,800,900,1000,1100,2000,3000,4000,5000,6000,7000,8000,9000];
mu=[5.00000000000000e-06,7.50000000000000e-06,1.00000000000000e-05,1.00000000000000e-05,1.50000000000000e-05,2.00000000000000e-05,2.50000000000000e-05,3.50000000000000e-05,6.25000000000000e-05,0.000100000000000000,0.000100000000000000,0.000100000000000000,0.000100000000000000,0.000100000000000000,0.000100000000000000,0.000150000000000000,0.000200000000000000,0.000300000000000000,0.000325000000000000,0.000375000000000000,0.000750000000000000,0.000750000000000000,0.000750000000000000,0.00100000000000000,0.00150000000000000,0.00250000000000000,0.00300000000000000,0.00541666700000000,0.00583333300000000,0.00933333300000000,0.0140000000000000,0.0230000000000000,0.0350000000000000,0.0475000000000000,0.0600000000000000,0.102500000000000,0.130000000000000,0.145000000000000,0.145000000000000,0.117142857000000,0.0809523810000000,0.0476190480000000,0.0809523810000000,0.117142857000000,0.145000000000000,0.145000000000000,0.130000000000000,0.102500000000000,0.0600000000000000,0.0475000000000000,0.0350000000000000,0.0230000000000000,0.0140000000000000,0.00933333300000000,0.00583333300000000,0.00541666700000000,0.00300000000000000,0.00250000000000000,0.00150000000000000,0.00100000000000000,0.000750000000000000,0.000750000000000000,0.000750000000000000,0.000375000000000000,0.000325000000000000,0.000300000000000000,0.000200000000000000,0.000150000000000000,0.000100000000000000,0.000100000000000000,0.000100000000000000,0.000100000000000000,0.000100000000000000,0.000100000000000000,6.25000000000000e-05,3.50000000000000e-05,2.50000000000000e-05,2.00000000000000e-05,1.50000000000000e-05,1.00000000000000e-05,1.00000000000000e-05,7.50000000000000e-06,5.00000000000000e-06];
olivetianqin 当前离线   回复时引用此帖
旧 2009-05-05, 15:42   #2
myci
注册日期: 2008-10-16
年龄: 45
声望力: 17
myci 正向着好的方向发展
默认 回复: 急请教:正态分布曲线拟合问题
引用:
作者: olivetianqin 查看帖子
数据如下:
呵呵 在matlab里用确定函数进行拟合我还不太会,不过我可以在告诉函数情况下用fortran最小二乘法拟合!
myci 当前离线   回复时引用此帖
所有时间均为北京时间。现在的时间是 09:13
