旧 2007-08-07, 16:01   #1
linwy
注册日期: 2007-08-07
linwy 正向着好的方向发展
默认 【求助】matlab在linux下安装后运行的问题
大家好,我在linux下装了个matlab,但是运行时的问题是:
[wylin@node37 bin]$ ./matlab -nodesktop
< M A T L A B >
Copyright 1984-2005 The MathWorks, Inc.
Version 7.0.4.352 (R14) Service Pack 2
January 29, 2005
Warning: MATLAB Toolbox Path Cache is out of date and is not being used.
Type 'help toolbox_path_cache' for more info.
Warning: Name is nonexistent or not a directory: <PLEASE FILL IN ONE DIRECTORY PER LINE>.
Undefined function or variable "ispc".
Warning: MATLAB did not appear to successfully set the search path. To avoid this
warning the next time you start MATLAB, use
http://www.mathworks.com/access/help.../pathdef.shtml
to help troubleshoot the "pathdef.m" file. To recover for this session
of MATLAB, type "restoredefaultpath;matlabrc".
??? Undefined command/function 'colordef'.
Error in ==> hgrc at 59
colordef(0,'white') % Set up for white defaults
Error in ==> matlabrc at 91
hgrc
我输入restoredefaultpath;matlabrc命令时
Warning: Duplicate directory name: /public1/Matlab7/toolbox/stateflow/stateflow.
> In restoredefaultpath at 50
Warning: Duplicate directory name: /public1/Matlab7/toolbox/rtw/rtw.
Warning: Duplicate directory name: /public1/Matlab7.
Warning: Duplicate directory name: /public1/Matlab7/toolbox/shared/optimlib.
??? Undefined function or variable 'matlabrc'.
>> quit
??? The path may be bad. Please save your work (if desired), and quit.
>> quit
[wylin@node37 bin]$
其中有些命令可以运行 比如 rand,size,cd
但是dir,help等运行不了,哪位大哥知道这是怎么回事?
Warning: MATLAB did not appear to successfully set the search path 这个问题如何解决啊?
linwy 当前离线   回复时引用此帖
所有时间均为北京时间。现在的时间是 08:59
