旧 2008-12-01, 10:38   #1
alex_magicsky
注册日期: 2008-09-02
声望力: 17
alex_magicsky 正向着好的方向发展
默认 Simulink仿真modle error
错误提示:Derivative input 1 of 'sever/Transfer Fcn' at time 0.08212698554400622 is Inf or NaN. Stopping simulation. There may be a singularity in the solution. If not, try reducing the step size (either by reducing the fixed step size or by tightening the error tolerances).
source:unknown
Simulink之中的debugger中的有错误的模块的输出:Warning: 'Signal storage reuse' is enabled for this model. Block I/O values displayed in the debugger may be not be correct.
In order to preserve block output signal values, consider disabling the 'Signal storage reuse' option in the 'Optimization' page of the Configuration Parameters dialog.
> In <a href="error:\Program Files\MATLAB\R2007a\toolbox\simulink\simulink\sldebugui.m,71,1">sldebugui at 71</a>
Warning: 'Block reduction optimization' is enabled for this model. Some non-virtual blocks may not execute due to optimization.
To be able to execute all non-virtual blocks consider disabling the 'Block reduction optimization' option in the 'Optimization' page of the Configuration Parameters dialog.
Warning: Using a default value of 0.2 for maximum step size. The simulation step size will be equal to or less than this value. You can disable this diagnostic by setting 'Automatic solver parameter selection' diagnostic to 'none' in the Diagnostics page of the configuration parameters dialog.
上传的附件
文件类型: doc 新建 Microsoft Word 文档.doc (23.5 KB, 6 次查看)
alex_magicsky 当前离线   回复时引用此帖
旧 2008-12-01, 11:06   #2
alex_magicsky
注册日期: 2008-09-02
声望力: 17
默认 回复: Simulink仿真modle error
在下刚刚接触不久,遇到这个问题很是费解,希望各位高手不吝赐教,在下感激不尽!
旧 2010-03-24, 14:07   #3
alx
注册日期: 2008-11-13
年龄: 37
alx 正向着好的方向发展
检查你的系统是否稳定,可能是不稳定,数据溢出。
alx 当前离线   回复时引用此帖
请教怎么解这个递归方程 lohas1985 MATLAB论坛 0 2009-03-12 14:34
[求助]请教一个曲面取点的问题,谢谢了先 thincat MATLAB论坛 0 2008-12-25 16:59
"一个累积求和的问题",请教高手 spurs001 MATLAB论坛 0 2008-05-27 09:53
【资料】IEEE 802.11a WLAN model yesman MATLAB论坛 4 2007-07-19 09:27
【求助】求教关于卷积编码的MATLAB建模,仿真 xiangyang198496 MATLAB论坛 1 2007-06-05 19:15
所有时间均为北京时间。现在的时间是 09:53
