#1 |
注册日期: 2008-07-11
声望力: 0 ![]() |
Wp=30;Ws=50;Rp=1;As=30;
Ripple=10^(-Rp/20); Attn=10^(-As/20); [b,a]=afd_butt(Wp,Ws,Rp,As) [C,B,A]=sdir2cas(b,a) [db,mag,pha,w]=freqs_m(b,a,50); [ha,x,t]=impulse(b,a); figure(1);clf; subplot(2,2,1);plot(w,mag);title('Magnitude Response'); xlabel('Analog frequency in rad/s'); ylabel('H'); % axis([0,50,0,1.1]) set(gca,'Xtickmode','manual','Xtick',[0,30,40,50]); set(gca,'Ytickmode','manual','Ytick',[0,Attn,Ripple,1]); grid subplot(2,2,2);plot(w,db);title('Magnitude in dB'); xlabel('Analog frequency in rad/s'); ylabel('decibels'); % axis([0,50,-40,5]) set(gca,'Xtickmode','manual','Xtick',[0,30,40,50]); set(gca,'Ytickmode','manual','Ytick',[-40,-As,-Rp,0]); grid subplot(2,2,3);plot(w,pha/pi);title('Phase Response'); xlabel('Analog frequency in rad/s'); ylabel('radians'); % axis([0,50,-1.1,1.1]) set(gca,'Xtickmode','manual','Xtick',[0,30,40,50]); set(gca,'Ytickmode','manual','Ytick',[-1,-0.5,0,0.5,1]); grid subplot(2,2,4);plot(t,ha);title('Impulse Response'); xlabel('time in seconds'); ylabel('ha(t)'); axis([0,max(t)+0.05,min(ha),max(ha)+0.025]); set(gca,'Xtickmode','manual','Xtick',[0,0.1,max(t)]); set(gca,'Ytickmode','manual','Ytick',[0,0.1,max(ha)]); grid %巴特沃兹模拟滤波器的设计程序 function[b,a]=afd_butt(Wp,Ws,Rp,As); if Wp<=0 error('Passband edge must be larger than 0') end if Ws<=Wp error('Stopband edge must be larger than Passed edge') end if(Rp<=0)|(As<0) error('PB ripple and /Or SB attenuation must be larger than 0') end N=ceil((log10((10^(Rp/10)-1)/(10^(As/10)-1)))/(2*log10(Wp/Ws))); OmegaC=Wp/((10^(Rp/10)-1)^(1/(2*N))); [b,a]=u_buttap(N,OmegaC); %设计非归一化巴特沃兹模拟低通滤波器原型子程序 function [b,a]=u_buttap(N,OmegaC); [z,p,k]=buttap(N); p=p*OmegaC; k=k*OmegaC^N; B=real(poly(z)); b0=k; b=k*B; a=real(poly(z)); %计算系统函数的幅度响应和相位响应子程序 function [db,mag,pha,w]=freqs_m(b,a,wmax); w=[0:1:500]*wmax/500; H=freqs(b,a,w); mag=abs(H); db=20*log10((mag+eps)/max(mag)); pha=angle(H); %直接形式转换成级联形式子程序 function [C,B,A]=sdir2cas(b,a); Na=length(a)-1;Nb=length(b)-1; b0=b(1);b=b/b0; a0=a(1);a=a/a0; C=b0/a0; p=cplxpair(roots(a));K=floor(Na/2); if K*2==Na a=zeros(K,3); for n=1:2:Na Arow=p(n:1:n+1, ![]() A(fix((n+1)/2), ![]() end elseif Na==1 A=[0 real(poly(p))]; else A=zeros(K+1,3); for n=1:2:2*K Arow=p(n:1:n+1, ![]() A(fix((n+1)/2), ![]() end A(K+1, ![]() end z=cplxpair(roots(b));K=floor(Nb/2); if Nb==0 B=[0 0 poly(z)]; elseif K*2==Nb B=zeros(K,3); for n=1:2:Nb Brow=z(n:1:n+1, ![]() B(fix((n+1)/2), ![]() end elseif Nb==1 B=[0 real(poly(z))]; else B=zeros(K+1,3); for n=1:2:2*K Brow=z(n:1:n+1, ![]() B(fix((n+1)/2), ![]() end B(K+1, ![]() end 这是一个巴特沃兹滤波器的设计,执行后出现??? One or more output arguments not assigned during call to 'sdir2cas'. 请教高手这是什么问题呢?怎么解决?谢谢!!!! |
主题 | 主题作者 | 版面 | 回复 | 最后发表 |
求助:双大括号与单大括号的区别! | wupeng0618 | MATLAB论坛 | 1 | 2008-07-14 19:31 |
[求助]想利用matcom在VC.net中绘制静态三维曲线的疑问 | lmmf | MATLAB论坛 | 0 | 2008-05-14 15:42 |
[求助]求取样调函数基准点曲率问题 | payson | MATLAB论坛 | 0 | 2008-05-01 08:24 |
【求助】如何用MATLAB读出图片信息? | flp5521 | MATLAB论坛 | 4 | 2008-04-03 10:29 |
【求助】急!求助 | riderwei | MATLAB论坛 | 1 | 2007-05-29 18:43 |
