旧 2008-05-27, 12:34   #1
linda1970
注册日期: 2008-05-27
年龄: 54
linda1970 正向着好的方向发展
尴尬 [求助]matlab轉換cmy及hsi
請問各位如何用MATLAB程式將彩色影像轉換為CMY(三張圖)及HSI(三張圖)。可否寫成完整程式感激不盡!!:cry:
linda1970 当前离线   回复时引用此帖
旧 2008-05-27, 21:16   #2
qxb0111
注册日期: 2008-05-15
qxb0111 正向着好的方向发展
默认
function hsi=rgb2hsi(rgb)
%RGB2HSI Converts an RGB image to HSI
% HSI=RGB2HSI(rgb) converts an RGB image to HSI. The input image is
% assumed to be of size M-by-N-by-3, where the third dimension accounts
% for three image planes:red, green, and blue, in that order. If all RGB
% component images are equal, the HSI conversion is undefined. Ths input
% image can be of class double (with values in the rang[0,1]), uint8, or
% uint16.
% The output image, HSI, is of class double, where:
% hsi(:,:,1)= hue image normalized values to the range [0,1] by
% dividing all angle values by 2*pi.
% hsi(:,:,2)=saturation image, in the range [0,1].
% hsi(:,:,3)=intensity image, in the range [0,1].
%Extract the individual component images.
rgb=im2double(rgb);
r=rgb(:,:,1);
g=rgb(:,:,2);
b=rgb(:,:,3);
%Implement the conversion equations.
num=0.5*((r-g)+(r-b));
den=sqrt((r-g).^2+(r-b).*(g-b));
theta=acos(num./(den+eps));
H=theta;
H(b>g)=2*pi-H(b>g);
H=H/(2*pi);
num=min(min(r,g),b);
den=r+g+b;
den(den==0)=eps;
S=1-3.*num./den;
H(S==0)=0;
I=(r+g+b)/3;
%Combine all three results into an hsi image.
hsi=cat(3,H,S,I);
qxb0111 当前离线   回复时引用此帖
旧 2008-05-28, 09:39   #3
linda1970
注册日期: 2008-05-27
年龄: 54
linda1970 正向着好的方向发展
默认 並未解決,再麻煩幫幫忙.....
非常感謝你的解答,但我看不出來圖片檔要放在哪個位置,且我要的事cmy及hsi兩個只看得到hsi在麻煩你幫忙解決.謝謝!!:cry:
新手请教如何缩短时间 mtseasky MATLAB论坛 1 2008-07-26 01:36
求助:向量分段求乘积 fifa2002qwe MATLAB论坛 2 2008-06-01 22:02
matlab 中反函数运算。 zhanggongrui MATLAB论坛 0 2008-04-29 00:03
BMP图像转换成时间序列 zlnhappy MATLAB论坛 0 2008-04-28 17:53
求救-----基于小波域的数字水印 tcgqb111 MATLAB论坛 0 2007-05-24 07:27
所有时间均为北京时间。现在的时间是 09:21
