旧 2008-04-21, 15:55   #1
28637634
注册日期: 2008-04-20
声望力: 18
28637634 正向着好的方向发展
默认 这是什么意思呢?(Next power of 2 from length of y)
A common use of Fourier transforms is to find the frequency components
of a signal buried in a noisy time domain signal. Consider data sampled at
1000 Hz. Form a signal containing a 50 Hz sinusoid of amplitude 0.7 and 120
Hz sinusoid of amplitude 1 and corrupt it with some zero-mean random noise:
Fs = 1000; % Sampling frequency
T = 1/Fs; % Sample time
L = 1000; % Length of signal
t = (0:L-1)*T; % Time vector
% Sum of a 50 Hz sinusoid and a 120 Hz sinusoid
x = 0.7*sin(2*pi*50*t) + sin(2*pi*120*t);
y = x + 2*randn(size(t)); % Sinusoids plus noise
plot(Fs*t(1:50),y(1:50))
title('Signal Corrupted with Zero-Mean Random Noise')
xlabel('time (milliseconds)')
It is difficult to identify the frequency components by looking at the
original signal. Converting to the frequency domain, the discrete Fourier
transform of the noisy signal y is found by taking the
fast Fourier transform (FFT):
NFFT = 2^nextpow2(L); % Next power of 2 from length of y
Y = fft(y,NFFT)/L;
f = Fs/2*linspace(0,1,NFFT/2);
% Plot single-sided amplitude spectrum.
plot(f,2*abs(Y(1:NFFT/2)))
title('Single-Sided Amplitude Spectrum of y(t)')
xlabel('Frequency (Hz)')
ylabel('|Y(f)|')
28637634 当前离线   回复时引用此帖
旧 2008-04-21, 16:48   #2
songzy41
注册日期: 2008-04-05
年龄: 83
声望力: 18
songzy41 正向着好的方向发展
默认
数组y的长度为L(L=1000),并不是2的幂次,通过函数计算出L的最接近的2的幂次,这时求出nfft=1024,这满足对长为2的幂次的FFT要求。所以在FFT时把y补0使长为nfft,作nfft的FFT。
songzy41 当前离线   回复时引用此帖
[求助]simulink系统仿真后转化为c代码问题 gekay MATLAB论坛 3 2008-06-19 19:47
[求助]用什么模块观察和测量EVM?谢谢了 chenxin_19344834 MATLAB论坛 0 2008-05-23 15:13
[求助]插值数据不对!!! ilikehere MATLAB论坛 2 2008-05-06 19:41
【求助】Simulink问题 liuxm0203 MATLAB论坛 2 2008-03-22 10:31
Cleve's Corner: Professor SVD TechnicalArticles MATLAB技术文章 0 2008-01-06 16:32
所有时间均为北京时间。现在的时间是 09:14
