旧 2008-03-28, 08:56   #1
landianxi
注册日期: 2008-03-28
landianxi 正向着好的方向发展
默认 [求助]smith圆图在matlab中的实现
小弟是电子信息专业的毕业生,要交论文了,题目是smith圆图在matlab中的实现,可我这方面没怎么学,不大会,教课书和网上都找不到相关的资料,无从下笔,请各位大仙帮帮忙,指点一二,提供点资料,小弟在此万分感谢。
landianxi 当前离线   回复时引用此帖
旧 2008-11-24, 18:42   #2
mikle
注册日期: 2008-07-10
年龄: 43
声望力: 17
mikle 正向着好的方向发展
默认 回复: 【求助】smith圆图在matlab中的实现
%Victor Aprea Cornell University 6/27/02
%Usage: plotsmithchart(Zl,Zo)
% where Zl is the Load Impedence (possibly complex)
% and Zo is the Characteristic Line Impedence
% Plots a smith chart, along with the reflection coefficient circle
% and the line of intersection with resistive component equal to 1.
% plotsmithchart
% Without any parameters draws a blank smith chart.
% Wavelengths toward the generator are labeled around the perimeter
%For example: plotsmithchart(25,50)
% Draws a smithchart, calculates and plots the reflection coefficient
% for a characteristic impedence of 50 ohms and a load impedence of 25 ohms,
% and draws the line of intersection with the R=1 circle.
function answer = plotSmithChart(Zl,Zo);
constant = linspace(0,10,5);
phaseAngle = linspace(0,2*pi,50);
unitGamma = exp(j*phaseAngle);
%plot the unit circle in the complex plane
hold on;
plot(real(unitGamma),imag(unitGamma),'r');
%set(gcf,'Position',[0 0 1280 990]);
axis square
zoom on
axis([-1.1 1.1 -1.1 1.1]);
MAX=2001;
bound2=0;
bound3=0;
min_bound1=0;
min_bound2=0;
max_bound2=0;
H=0;
word=0;
Gr = linspace(-1,1,MAX);
hold on;
interval = [[.01:.01:.2],[.22:.02:.5],[.55:.05:1],[1.1:.1:2],[2.2:.2:5],[6:10],[12:2:20],[30:10:50]];
interval2= [[.01:.01:.5],[.55:.05:1],[1.1:.1:2],[2.2:.2:5],[6:10],[12:2:20],[30:10:50]];
%plot real axis
plot(Gr, zeros(1,length(Gr)),'r');
%equations were derived using the symbolic toolbox as follows
%solve('R=(1-Gr^2-Gi^2)/((1-Gr)^2+Gi^2)','Gi')
%bound was derived as follows
%solve('1/(R+1)*(-(R+1)*(R-2*R*Gr+R.*Gr^2-1+Gr^2))^(1/2)=0','Gr')
for R = interval2,
min_bound1 = (R-1)/(R+1);
if(R<.2)
if(mod(R,.1)==0)
max_bound = (-1+2^2+R^2)/(2^2+R^2+2*R+1);
elseif(mod(R,.02)==0)
max_bound = (-1+.5^2+R^2)/(.5^2+R^2+2*R+1);
else
max_bound = (-1+.2^2+R^2)/(.2^2+R^2+2*R+1);
if(R==.05 | (R<.151 & R>.149))
min_bound2 = (-1+.5^2+R^2)/(.5^2+R^2+2*R+1);
max_bound2 = (-1+1^2+R^2)/(1^2+R^2+2*R+1);
elseif(R<1)
if(mod(R,.2)==0)
max_bound = (-1+5^2+R^2)/(5^2+R^2+2*R+1);
elseif(mod(R,.1)==0)
elseif(R==.25 | R==.35 | R==.45)
temp = (-1+.5^2+R^2)/(.5^2+R^2+2*R+1);
min_bound2 = max(min_bound1, temp);
max_bound = (-1+1^2+R^2)/(1^2+R^2+2*R+1);
elseif(R<.5)
else
elseif(R<5)
if(mod(R,2)==0)
max_bound = (-1+20^2+R^2)/(20^2+R^2+2*R+1);
elseif(mod(R,1)==0)
max_bound = (-1+10^2+R^2)/(10^2+R^2+2*R+1);
elseif(R>2)
else
if(mod(R,.2)==0)
else
elseif(R<10)
if(mod(R,2)==0)
else
else
if(R==10|R==20)
max_bound = (-1+50^2+R^2)/(50^2+R^2+2*R+1);
elseif(R==50)
max_bound = 1;
elseif(R<20)
else
index = ceil((min_bound1+1)*(MAX-1)/2+1);
actual_value = Gr(index);
if(actual_value<min_bound1)
index = index + 1;
MIN=index;
index = ceil((max_bound+1)*(MAX-1)/2+1);
if(actual_value>max_bound)
index = index - 1;
MIN2 = ceil((min_bound2+1)*(MAX-1)/2+1);
actual_value = Gr(MIN2);
if(actual_value<min_bound2 )
MIN2 = MIN2 + 1;
MAX2 = ceil((max_bound2+1)*(MAX-1)/2+1);
actual_value = Gr(MAX2);
if(actual_value<max_bound2 )
MAX2 = MAX2 + 1;
r_L_a=1/(R+1)*(-(R+1)*(R-2*R.*Gr(MIN:index)+R.*Gr(MIN:index).^2-1+Gr(MIN:index).^2)).^(1/2);
r_L_b=-1/(R+1)*(-(R+1)*(R-2*R.*Gr(MIN:index)+R.*Gr(MIN:index).^2-1+Gr(MIN:index).^2)).^(1/2);
r_L_b(1)=0;
r_L_a(1)=0;
r_L_a2=1/(R+1)*(-(R+1)*(R-2*R.*Gr(MIN2:MAX2)+R.*Gr(MIN2:MAX2).^2-1+Gr(MIN2:MAX2).^2)).^(1/2);
r_L_b2=-1/(R+1)*(-(R+1)*(R-2*R.*Gr(MIN2:MAX2)+R.*Gr(MIN2:MAX2).^2-1+Gr(MIN2:MAX2).^2)).^(1/2);
r_L_a3=1/(R+1)*(-(R+1)*(R-2*R.*Gr(MIN2:index)+R.*Gr(MIN2:index).^2-1+Gr(MIN2:index).^2)).^(1/2);
r_L_b3=-1/(R+1)*(-(R+1)*(R-2*R.*Gr(MIN2:index)+R.*Gr(MIN2:index).^2-1+Gr(MIN2:index).^2)).^(1/2);
%fix resolution issues in .2-.5 range
if(~(R>.2 & R<.5 & ~(mod(R,.02)==0)))
if(R==1)
color = 'r';
else
color ='b';
plot(Gr(MIN:index),r_L_a(1:index-MIN+1),color,Gr(MIN:index), r_L_b(1:index-MIN+1),color);
if(R<=1)
if(mod(R,1)==0)
word = [num2str(R) '.0'];
else
word = num2str(R);
if(mod(R,.1)==0)
set(text(Gr(MIN),0,word),'Rotation',90,'HorizontalAlignment','left','VerticalAlignment','bottom');
elseif(R<=2)
if(mod(R,.2)==0)
if(mod(R,1)==0)
else
word = num2str(R);
elseif(R<=5)
if(mod(R,1)==0)
set(text(Gr(MIN),0,[num2str(R) '.0']),'Rotation',90,'HorizontalAlignment','left','VerticalAlignment','bottom');
else
if(mod(R,10)==0)
set(text(Gr(MIN),0,num2str(R)),'Rotation',90,'HorizontalAlignment','left','VerticalAlignment','bottom');
plot(Gr(MIN2:index),r_L_a3,'b');
plot(Gr(MIN2:index),r_L_b3,'b');
if(R==.05 | (R>.149 & R<.151))
plot(Gr(MIN2:MAX2),r_L_a2(length(Gr(MIN2:MAX2))-length(r_L_a2)+1:length(r_L_a2)),'b');
plot(Gr(MIN2:MAX2),r_L_b2(length(Gr(MIN2:MAX2))-length(r_L_b2)+1:length(r_L_b2)),'b');
%solve('2*Gi/((1-Gr)^2+Gi^2)=x','Gi')
%solve('1-X^2+2*X^2*Gr-X^2*Gr^2=0','Gr')
%solve('1/2/X*(2+2*(1-X^2+2*X^2*Gr-X^2*Gr^2)^(1/2))=(1-Gr^2)^(1/2)','Gr')
for X = interval,
inter_bound = (-1+X^2)/(X^2+1); %intersection with unit circle: all values must be less than this\
imag_bound = (-1+X)/X; %boundary of imagination: all values must be greater than this
angle_point = 0;
if(inter_bound ~= 0)
angle_point = sqrt(1-inter_bound^2)/inter_bound;
imag_bound_y = 1/2/X*(-2+2*(1-X^2+2*X^2.*inter_bound-X^2.*inter_bound.^2).^(1/2));
imag_rad = (imag_bound^2 + imag_bound_y^2)^(1/2);
condition = imag_rad < 1;
if(inter_bound > 1)
inter_bound = 1;
elseif(inter_bound < -1)
imag_bound=-1;
if(imag_bound > 1)
imag_bound = 1;
elseif(imag_bound < -1)
imag_bound=-1;
%used solve function to find intersection of appropriate circle with corresponding hyperbolics
%solve('-1/(R+1)*(-(R+1)*(R-2*R*Gr+R*Gr^2-1+Gr^2))^(1/2)=1/2/X*(-2+2*(1-X^2+2*X^2*Gr-X^2*Gr^2)^(1/2))','Gr')
%The following conditional tree creates the internal bounding between the two types of curves for variable resolution
if(X<.2)
if(mod(X,.1)==0)
max_bound = (-1+X^2+2^2)/(X^2+2^2+2*2+1);
elseif(mod(X,.02)==0)
max_bound = (-1+X^2+.5^2)/(X^2+.5^2+2*.5+1);
else
max_bound = (-1+X^2+.2^2)/(X^2+.2^2+2*.2+1);
elseif(X<1)
if(mod(X,.2)==0)
max_bound = (-1+X^2+5^2)/(X^2+5^2+2*5+1);
elseif(mod(X,.1)==0)
elseif(X<.5)
else
max_bound = (-1+X^2+1^2)/(X^2+1^2+2*1+1);
elseif(X<5)
if(mod(X,2)==0)
max_bound = (-1+X^2+20^2)/(X^2+20^2+2*20+1);
elseif(mod(X,1)==0)
max_bound = (-1+X^2+10^2)/(X^2+10^2+2*10+1);
elseif(X>2)
else
if(mod(X,.2)==0)
else
elseif(X<10)
if(mod(X,2)==0)
else
else
if(X==10|X==20)
max_bound = (-1+X^2+50^2)/(X^2+50^2+2*50+1);
elseif(X==50)
max_bound = 1;
elseif(X<20)
else
inter_index = ceil((inter_bound+1)*(MAX-1)/2+1);
imag_index = ceil((imag_bound+1)*(MAX-1)/2+1);
index4 = ceil((max_bound+1)*(MAX-1)/2+1);
index1 = max(inter_index,imag_index); %maximum index for c,d
index2 = min(imag_index,inter_index); %minimum index for c,d
if(condition)
index3=imag_index;
else
index3=inter_index;
actual_value1 = Gr(index1);
actual_value2 = Gr(index2);
actual_value3 = Gr(index3);
actual_value4 = Gr(index4);
if((actual_value1 > inter_bound & index1 == inter_index)|(actual_value1 > imag_bound & index1 == imag_index))
index1 = index1 - 1;
if((actual_value2 < inter_bound & index2 == inter_index)|(actual_value2 < imag_bound & index2 == imag_index))
index2 = index2 + 1;
if((actual_value3 < inter_bound & index3 == inter_index)|(actual_value3 < imag_bound & index3 == imag_index))
index3 = index3 + 1;
if(actual_value4 > max_bound)
index4 = index4 - 1;
MIN=index2;
MAX2=index1;
MAX3=index4;
MIN2 = index3;
% actual_value1 = Gr(MIN);
% actual_value2 = Gr(MAX2);
% MIN=1;
% MAX2=MAX;
% MIN2=1;
x_L_a = real(1/2/X*(-2+2*(1-X^2+2*X^2.*Gr(MIN2:MAX3)-X^2.*Gr(MIN2:MAX3).^2).^(1/2)));
x_L_b = real(1/2/X*(2-2*(1-X^2+2*X^2.*Gr(MIN2:MAX3)-X^2.*Gr(MIN2:MAX3).^2).^(1/2)));
x_L_c= real(1/2/X*(2+2*(1-X^2+2*X^2.*Gr(MIN:MAX2)-X^2.*Gr(MIN:MAX2).^2).^(1/2)));
x_L_d= real(1/2/X*(-2-2*(1-X^2+2*X^2.*Gr(MIN:MAX2)-X^2.*Gr(MIN:MAX2).^2).^(1/2)));
if(MIN2<MAX3)
x_L_c(1)=x_L_b(1);
x_L_d(1)=x_L_a(1);
check1 = abs(round(10000*1/2/X*(-2-2*(1-X^2+2*X^2*inter_bound-X^2*inter_bound^2)^(1/2))));
check2 = abs(round(10000*(1-inter_bound^2)^(1/2)));
if(imag_bound > -1 & check1 == check2)
plot(Gr(MIN:MAX2),x_L_c,'g')
plot(Gr(MIN:MAX2),x_L_d,'g')
plot(Gr(MIN2:MAX3),x_L_a,'g')
plot(Gr(MIN2:MAX3),x_L_b,'g')
condition = Gr(MIN2)^2 + x_L_d(1)^2 > .985;
if(X<=1)
if(mod(X,.1)==0)
if(mod(X,1)==0)
word = [num2str(X) '.0'];
else
word = num2str(X);
if(X==1)
angle = 90;
else
angle = -atan(angle_point)*180/pi;
set(text(Gr(MIN2),x_L_d(1),word),'Rotation',angle,'VerticalAlignment','bottom','HorizontalAlignment','left');
set(text(Gr(MIN2),-x_L_d(1),word),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom');
if(mod(X,.2)==0)
xval=X^2/(X^2+4);
yval = 1/2/X*(-2+2*(1-X^2+2*X^2*xval-X^2*xval^2)^(1/2));
angle = -atan(yval/(.5-xval))*180/pi;
set(text(xval,yval,word),'Rotation',angle,'HorizontalAlignment','left','VerticalAlignment','bottom');
set(text(xval,-yval,word),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom')
elseif(X<=2)
if(mod(X,.2)==0)
if(mod(X,1)==0)
else
word = num2str(X);
if(condition)
angle = -atan(angle_point)*180/pi+180;
set(text(Gr(MIN2),x_L_a(1),word),'Rotation',angle,'VerticalAlignment','bottom','HorizontalAlignment','left');
set(text(Gr(MIN2),-x_L_a(1),word),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom');
else
set(text(Gr(MAX2),x_L_d(length(x_L_d)),word),'Rotation',angle,'VerticalAlignment','bottom','HorizontalAlignment','left');
set(text(Gr(MAX2),-x_L_d(length(x_L_d)),word),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom');
elseif(X<=5)
if(mod(X,1)==0)
if(condition)
set(text(Gr(MIN2),x_L_a(1),[num2str(X) '.0']),'Rotation',angle,'VerticalAlignment','bottom','HorizontalAlignment','left');
set(text(Gr(MIN2),-x_L_a(1),[num2str(X) '.0']),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom');
else
set(text(Gr(MAX2),x_L_d(length(x_L_d)),[num2str(X) '.0']),'Rotation',angle,'VerticalAlignment','bottom','HorizontalAlignment','left');
set(text(Gr(MAX2),-x_L_d(length(x_L_d)),[num2str(X) '.0']),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom');
else
if(mod(X,10)==0)
if(condition)
set(text(Gr(MIN2),x_L_a(1),num2str(X)),'Rotation',angle,'VerticalAlignment','bottom','HorizontalAlignment','left');
set(text(Gr(MIN2),-x_L_a(1),num2str(X)),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom');
else
set(text(Gr(MAX2),x_L_d(length(x_L_d)),num2str(X)),'Rotation',angle,'VerticalAlignment','bottom','HorizontalAlignment','left');
set(text(Gr(MAX2),-x_L_d(length(x_L_d)),num2str(X)),'Rotation',-angle+180,'HorizontalAlignment','right','VerticalAlignment','bottom');
%plot imaginary axis
plot(zeros(1,length(Gr)),Gr,'r');
wavelengths = 0:.01:.5;
angle = linspace(pi,-pi,length(wavelengths));
wave_circle = 1.05*exp(j*phaseAngle);
plot(real(wave_circle),imag(wave_circle),'r');
for i=1:length(wavelengths)-1,
x=real(1.025*exp(j*angle(i)));
y=imag(1.025*exp(j*angle(i)));
if(x>0)
rot_angle=atan(y/x)*180/pi-90;
else
rot_angle=atan(y/x)*180/pi+90;
if(wavelengths(i)==0)
word = '0.00';
elseif(mod(wavelengths(i),.1)==0)
word = [num2str(wavelengths(i)) '0'];
else
word = num2str(wavelengths(i));
set(text(x,y,word),'Rotation',rot_angle,'VerticalAlignment','middle','HorizontalAlignment','center');
%plot reflection coefficient and line of intersection only if arguments are present
if(nargin == 2)
radius = abs((Zl-Zo)/(Zl+Zo));
Load_circle=radius*exp(j*phaseAngle);
plot(real(Load_circle),imag(Load_circle),'r');
slope = (-(1-radius^2)^(1/2)*radius)/(radius^2);
value=1/(1+slope^2)^(1/2);
MAX2 = ceil((value+1)*(MAX-1)/2+1);
if(actual_value>value)
MAX2 = MAX2 - 1;
%plot line of intersection
line = slope*Gr(fix(MAX/2):MAX2);
plot(Gr(fix(MAX/2):MAX2),line,'r');
专业matlab源码工作室,有偿提供各类算法程序
email:[email protected]
QQ:63370633
期待与您合作[主页]
mikle 当前离线   回复时引用此帖
旧 2010-10-06, 10:27   #3
kaizi5156
注册日期: 2010-08-25
kaizi5156 正向着好的方向发展
默认 回复: [求助]smith圆图在matlab中的实现
真的是太谢谢了,最近在学smith圆图,想用MATLAB实现一个,正想着找例子学习呢!
kaizi5156 当前离线   回复时引用此帖
[求助]求..正态分布,卡方分布,F分布,T分布的MATLAB代码??? yang25107749 MATLAB论坛 7 2010-04-09 18:44
[求助]关于constant的用法 gonger1986 MATLAB论坛 0 2009-03-17 18:47
在matlab图片中如何编辑斜体字母——谢谢 clojj MATLAB论坛 0 2009-01-14 16:51
[求助]直接转矩控制问题 shevchen7 MATLAB论坛 1 2009-01-05 08:35
[分享]研究生必读 guofeng0108 MATLAB论坛 2 2008-12-12 19:38
所有时间均为北京时间。现在的时间是 09:17
