旧 2013-01-13, 12:53   #1
zk542648265
注册日期: 2013-01-13
zk542648265 正向着好的方向发展
问题 基于MATLAB的谱估计和自适应程序 求助
以下为谱估计和自适应程序,哪位大神能帮我注解下程序的语句和告诉我流程图是什么?
clear;
clc;
%Burg Data leng N=64
clear;
clc;
N=1024;
n=[0:N-1];
randn('state',0);
wn=randn(1,N);
xn=sqrt(20)*sin(2*pi*0.1*n)+sqrt(20)*sin(2*pi*0.4*n)+wn;
ef(1,=xn;
eb(1,=xn;
tempsum=0;
for i=1:1:N
tempsum=tempsum+xn(i).*xn(i);
thegma(1)=tempsum/N;
%p=1
sum1=0;
sum2=0;
for n=2:N,
sum1=sum1+ef(1,n)*eb(1,n-1);
sum2=sum2+abs(ef(1,n))^2+abs(eb(1,n-1))^2;
a(1,1)=-2*sum1/sum2;
thegma(2)=(1-abs(a(1,1))^2)*thegma(1);
for n=3:N,
ef(2,n)=ef(1,n)+a(1,1)*eb(1,n-1);
eb(2,n)=eb(1,n-1)+a(1,1)*ef(1,n);
p=1;
IP=14;
while p<IP
p=p+1;
sum1=0;
sum2=0;
for i=p+1:N
sum1=sum1+ ef(p,i)*eb(p,i-1);
sum2=sum2+ef(p,i)*ef(p,i)+eb(p,i-1)*eb(p,i-1);
a(p,p)=-2*sum1/sum2;
thegma(p+1)=[1-(abs(a(p,p)))^2]*thegma(p);
for i=p+2:N
ef(p+1,i)=ef(p,i)+a(p,p)*eb(p,i-1);
eb(p+1,i)=eb(p,i-1)+a(p,p)*ef(p,i);
for k=1:1-1
a(p,k)=a(p-1,k)+a(p,p)*a(p-1,p-k);
b=[1,a(p,,zeros(1,N-p-1)];
Pxx=abs(thegma(p))./((abs(fft(b))).^2);
Pxx=Pxx(1:N/2);
Pxx=10*log10(Pxx);
n=[0:N-1];
n=n(1:N/2);
% subplot(2,2,1);
plot(n/N,Pxx);
xlabel('Frequency');
ylabel('Power Spectrum (dB)');
title('Burg Data leng N=64');
grid on;
2、自适应的程序
clear all
close all
%channel system order
sysorder = 5 ;
% Number of system points
N=2000;
inp = randn(N,1);
n = randn(N,1);
[b,a] = butter(2,0.25);
Gz = tf(b,a,-1);
%This function is submitted to make inverse Z-transform (Matlab central file exchange)
%The first sysorder weight value
%h=ldiv(b,a,sysorder)';
% if you use ldiv this will give h :filter weights to be
h= [0.0976;
0.2873;
0.3360;
0.2210;
0.0964;];
y = lsim(Gz,inp);
%add some noise
n = n * std(y)/(10*std(n));
d = y + 3*n;
totallength=size(d,1);
%Take 60 points for training
N=60 ;
%begin of algorithm
w = zeros ( sysorder , 1 ) ;
for n = sysorder : N
u = inp(n:-1:n-sysorder+1) ;
y(n)= w' * u;
e(n) = d(n) - y(n) ;
if n < 20
mu=0.32;
else
mu=0.15;
w = w + mu * u * e(n) ;
%check of results
for n = N+1 : totallength
y(n) = w' * u ;
hold on
plot(d)
plot(y,'r');
title('System output') ;
xlabel('Samples')
ylabel('True and estimated output')
figure
semilogy((abs(e))) ;
title('Error curve') ;
xlabel('Samples')
ylabel('Error value')
figure
plot(h, 'k+')
hold on
plot(w, 'r*')
legend('Actual weights','Estimated weights')
title('Comparison of the actual weights and the estimated weights') ;
axis([0 6 0.05 0.35])
% RLS 算法
randn('seed', 0) ;
rand('seed', 0) ;
NoOfData = 8000 ;
Order = 32 ;
Lambda = 0.98 ;
Delta = 0.001 ;
x = randn(NoOfData, 1) ;
h = rand(Order, 1) ;
d = filter(h, 1, x) ;
P = Delta * eye ( Order, Order ) ;
w = zeros ( Order, 1 ) ;
% RLS Adaptation
for n = Order : NoOfData ;
u = x(n:-1:n-Order+1) ;
pi_ = u' * P ;
k = Lambda + pi_ * u ;
K = pi_'/k;
e(n) = d(n) - w' * u ;
w = w + K * e(n) ;
PPrime = K * pi_ ;
P = ( P - PPrime ) / Lambda ;
w_err(n) = norm(h - w) ;
end ;
% Plot results
figure ;
plot(20*log10(abs(e))) ;
title('Learning Curve') ;
xlabel('Iteration Number') ;
ylabel('Output Estimation Error in dB') ;
figure ;
semilogy(w_err) ;
title('Weight Estimation Error') ;
ylabel('Weight Error in dB') ;
zk542648265 当前离线   回复时引用此帖
所有时间均为北京时间。现在的时间是 17:46
