#1 |
注册日期: 2009-10-18
声望力: 0 ![]() |
*** WARNING *** CP = 18.047 TIME= 16:31:13
Real constant 31 referenced by at least element types 2 and 4. *** WARNING *** CP = 18.047 TIME= 16:31:13 Real constant 20 referenced by at least element types 1 and 4. *** WARNING *** CP = 18.047 TIME= 16:31:13 Real constant 45 referenced by at least element types 2 and 4. *** WARNING *** CP = 18.047 TIME= 16:31:13 Real constant 46 referenced by at least element types 2 and 4. *** WARNING *** CP = 18.047 TIME= 16:31:14 Real constant 47 referenced by at least element types 2 and 4. *** WARNING *** SUPPRESSED MESSAGE CP = 18.047 TIME= 16:31:14 Real constant 19 referenced by at least element types 1 and 3. *** WARNING *** SUPPRESSED MESSAGE CP = 18.047 TIME= 16:31:14 Real constant 36 referenced by at least element types 1 and 3. *** WARNING *** SUPPRESSED MESSAGE CP = 18.047 TIME= 16:31:14 Real constant 52 referenced by at least element types 1 and 7. *** WARNING *** SUPPRESSED MESSAGE CP = 18.312 TIME= 16:31:18 The program chosen initial timestep/load-factor is arbitrary. It is necessary for the user to supply a suitable initial timestep/load-factor through the NSUB or DELTIM command for convergence and overall efficiency. *** WARNING *** SUPPRESSED MESSAGE CP = 23.500 TIME= 16:31:27 Coefficient ratio exceeds 1.0e8 - Check results. *** WARNING *** SUPPRESSED MESSAGE CP = 29.219 TIME= 16:31:35 There are 61 small equation solver pivot terms. *** ERROR *** SUPPRESSED MESSAGE CP = 29.312 TIME= 16:31:35 The value of UZ at node 16291 is 2.950580274E+20. It is greater than the current limit of 1000000. This generally indicates rigid body motion as a result of an unconstrained model. Verify that your model is properly constrained. 我只算个自重,都不能算,请问是怎么回事? |
