#1 |
注册日期: 2010-08-20
年龄: 37
声望力: 0 ![]() |
Warning: Trust-region-reflective algorithm does
not solve this type of problem, using active-set algorithm. You could also try the interior-point algorithm: set the Algorithm option to 'interior-point' and rerun. Local minimum possible. Constraints satisfied. fmincon stopped because the predicted change in the objective function is less than the default value of the function tolerance and constraints were satisfied to within the default value of the constraint tolerance. <stopping criteria details> No active inequalities. 是什么意思啊?这个问题怎么解决啊 |
