旧 2010-03-29, 21:25   #1
lxl723
注册日期: 2010-03-28
lxl723 正向着好的方向发展
帖子 求助:帮我看看哪出错了?
小弟想用embeded matlab function 模块,里面代码如下:
function[p,v,h,s]=tx(t,x)
p=psaturation(t);
[vwater,hwater,swater]=ptwater(p,t);
[vsteam,hsteam,ssteam]=ptsteam(p,t);
v=vwater+x*(vsteam-vwater);
h=hwater+x*(hsteam-hwater);
s=swater+x*(ssteam-swater);
其中p=psaturation(t);
是三个M函数,运行时正确无误,但当运行这个embeded matlab function 模块时出现以下错误:
1,Expected either a logical, char, single, or double.
Found an mxArray. mxArrays are returned from calls to the MATLAB interpreter and are not supported inside expressions. They may be used on the right-hand side of assignments and as arguments to MATLAB calls.
Function 'tx' (#82.131.137), line 6, column 13:
"vsteam"
2,Expected either a logical, char, single, or double.
Function 'tx' (#82.159.165), line 7, column 13:
"hsteam"
3,Expected either a logical, char, single, or double.
Function 'tx' (#82.187.193), line 8, column 13:
"ssteam"
4,Errors occurred during parsing of Embedded MATLAB function 'tx'(#82)
5,Embedded MATLAB Interface Error: Port width mismatch. Input port "x"(#89) expects a scalar. The signal is a one dimensional vector with 1 elements.
不知道是不是能这样调用函数的原因?望高手解答下!先谢谢了!
lxl723 当前离线   回复时引用此帖
旧 2010-04-01, 09:16   #2
xiaoyaoshanzi
注册日期: 2010-04-01
xiaoyaoshanzi 正向着好的方向发展
默认 回复: 求助:帮我看看哪出错了?
在应用函数时应该
p=@psaturation(t);、、、、、、、
xiaoyaoshanzi 当前离线   回复时引用此帖
旧 2010-04-01, 13:28   #3
lxl723
注册日期: 2010-03-28
lxl723 正向着好的方向发展
帖子 回复: 求助:帮我看看哪出错了?
首先谢谢楼上的回答,我试了下,还是报错,不过已找到解决办法,即把调用函数的代码写在此模块里就没有问题,和C的用法很相似。
lxl723 当前离线   回复时引用此帖
所有时间均为北京时间。现在的时间是 23:10
