#1 |
注册日期: 2009-05-24
声望力: 0 ![]() |
帮忙看下我的code ,请求指导sampling,decision 和 BER,SER的具体写法
要求: -data rate= 100kbps -4time oversampling(base band) - Matched filter * Root raised cosine filter -waterfall curve(Monte calro simulation) * BER of Eb/N0 * SER of SNR 同时还给出了 一个 “time domain sequence" (后面用rrcf)来conv后形成 filter 我的思路:1.建bitstream (data)2. 进行mapping 分出(1,-1) 3. 并串转换分出Real & Imag 4. 分别对Real & Imag 进行oversampling(4个4个一组) 5. 分别 通过 Pulse shapping filter 6. 把Real & Imag 转换成a+jb形式在加上noise 7.在与rrcf进行conv 8. 再分别对Real & Imag各部分采样 9.进行decision操作,把bitstream换成(1,0)的形式 9. 进行串并转换形成demo数据流 10. 与原数据流进行比较画出 bit error rate (BER) & symbol error rate(SER) 的关系图如要求 clear all %********************% % Preparation Part % %********************% br=100000; %bit rate %nd= ; %number of symbol %Eb_No=5; %Eb/No sr=50000 ;% symbol rate %********************% % Filter Part % %********************% % IPOINT=4; % number of oversample %R=0.2; %roll off factor %irfn=21; % number of filter taps %[xh] = hrollfcoef(irfn,IPOINT,sr,alfs,1); %T FILTER FUNCTION %[xh2] = hrollfcoef(irfn,IPOINT,sr,alfs,0); %R FILTER FUNCTION %BW=(1/2)*sr*(1+R); % bandwidth data=[1 0 1 0 1 1 1 0 0 0 1 1 0 1 1 0 0]; for k=1:length(data) if data(k)==0; data(k)=-1; else data(k)=1; end end %for i=0:12; % SNR error=0; for k=1:length(data)/2 Re(k)=data(2*k-1)/sqrt(2); Im(k)=data(2*k)/sqrt(2); end Re_over=zeros(1,length(data)/2*4); Im_over=zeros(1,length(data)/2*4); for k=1:length(data)/2 Re_over(4*k-3)=Re(k); Im_over(4*k-3)=Im(k); end %****************************% % Time domain sequence % %squence rrcf=[-0.0189 0.0106 0.0424 0.0520 0.0233 -0.0360 -0.0924 -0.1000 0.0263 0.1261 0.3136 0.4677 0.5273 0.4677 0.3136 0.1261 -0.0263 -0.1000 -0.0924 -0.0360 0.0233 0.0520 0.0424 0.0106 -0.0189]; R_sq=conv(Re_over,rrcf); I_sq=conv(Im_over,rrcf); tx=R_sq+j*I_sq; %transimte signle %****************************% % AWGN % Eb_No= [-3:10]; noise_gain=10^(-Eb_No/20)/sqrt(2); n0=randn(1)+j*randn(1); n=n0* noise_gain; rx=tx+n; % receive signle Re_rx=real(rx); Im_rx=imag(rx); %Root raised cosine filter R_rx=conv(Re_rx,rrcf); I_rx=conv(Im_rx,rrcf); %filter=rcosfir(R,n_T,rate,T); %****************************% % Sampling % %****************************% % Decision % R_rx_de= ; I_rx_de= ; %****************************% % Multiplexer % QPSK_r=(sqrt(1/2).*R_rx_de+sqrt(1/2).*I_rx_de); %****************************% % Compare % for i=1:length(data) if QPSK_r(i)~=data(i) error=error+1 end end ber=error/100000; %****************************% % PLOT % %****************************% % oversampling figure(1) subplot(2,1,1),stem(Re_over,'fill','--'),grid subplot(2,1,2),stem(Im_over,'fill','--'),grid % pulse shaping filter figure(2) subplot(2,1,1),stem(R_sq,'--'),grid subplot(2,1,2),stem(I_sq,'--'),grid figure(3) subplot(2,1,1),stem(R_rx,'--'),grid subplot(2,1,2),stem(I_rx,'--'),grid %BER OF Eb/N0 figure(4) semilogy(Eb_N0_dB,ber,'b.-'); hold on axis([-3 10 10^-5 0.5]) grid on xlabel('Eb/No, dB'); ylabel('Bit Error Rate'); % SER OF SNR figure(5) %axis([-1 11 -60 -5]); title('QPSK'); xlabel('SNR(dB)'); ylabel('SER(dB)'); semilogy(snr,ser) grid; %end 拜托拜托了 |
