#1 |
注册日期: 2009-11-08
住址: 上海
年龄: 37
声望力: 0 ![]() |
我以前电脑安装过matlab7.0,都是没问题的
由于电脑的原因,重新安装了一次 还是以前的安装软件 但是现在一打开就出现‘x找不到模块’ 不明白为什么 打开之后出现了 ------------------------------------------------------------------------ Segmentation violation detected at Sun Nov 08 07:52:08 2009 ------------------------------------------------------------------------ Configuration: MATLAB Version: 7.0.1.24704 (R14) Service Pack 1 MATLAB License: 222378 Operating System: Microsoft Windows XP Window System: Version 5.1 (Build 2600: Service Pack 3) Processor ID: x86 Family 15 Model 11 Stepping 2, AuthenticAMD Virtual Machine: Java 1.4.2_04 with Sun Microsystems Inc. Java HotSpot(TM) Client VM (mixed mode) Default Charset: ibm-1386_P100-2002 Register State: EAX = 00000000 EBX = 00000000 ECX = 7c809a0d EDX = 006b0001 ESI = 01217d00 EDI = 01417da0 EBP = 00cda3e4 ESP = 00cda354 EIP = 00000000 FLG = 00010212 Stack Trace: [0] numerics.dll:??$mfGenMatrixMult@N@@YAXPAUmxArray_tag@@00W4MM_Transpose@@1N@Z(0x014181a0, 0x01417da0, 0x014181e0, 0) + 532 bytes [1] numerics.dll:void __cdecl mfGenMatrixMult(struct mxArray_tag *,struct mxArray_tag *,struct mxArray_tag *,enum MM_Transpose,enum MM_Transpose)(0x014181a0, 0x01417da0, 0x014181e0, 0) + 120 bytes [2] numerics.dll:void __cdecl mfTimesTransposeFcn2DFloatPt(int,struct mxArray_tag * * const,int,struct mxArray_tag * * const)(0, 0x00cda598, 6, 0x00cda508) + 913 bytes [3] m_dispatcher.dll ![]() 后面大致一样,由于过长,省略...... 以前都是没有的 还望高手指教 是不是我电脑丢失了什么软件 导致matlab装的时候丢失了某些部分 如果是,需要安装哪些东西 还望指教 补充问题 |
