#1 |
注册日期: 2009-06-18
声望力: 0 ![]() |
原方程组见附件。
当方程个数为三时,编程如下: 函数的M文件为: function En=fentropy(u) c=u; En=zeros(3,1); syms x; En(1)=int(exp(c(1)+c(2)*x+c(3)*x^2),'x',0,1)-1; En(2)=int(x*exp(c(1)+c(2)*x+c(3)*x^2),'x',0,1)-0.87791; En(3)=int(x^2*exp(c(1)+c(2)*x+c(3)*x^2),'x',0,1)-0.77161; 调用程序如下: clear,clc; u=10*ones(3,1); c=fsolve(@fentropy,u) 不到两分钟可以解出c=[-433.1652; 992.7220; -565.3877] 当方程个数为四时,编程如下: 函数的M文件为: function En=fentropy(u) c=u; En=zeros(4,1); syms x; En(1)=int(exp(c(1)+c(2)*x+c(3)*x^2+c(4)*x^3),'x',0,1)-1; En(2)=int(x*exp(c(1)+c(2)*x+c(3)*x^2+c(4)*x^3),'x',0,1)-0.87791; En(3)=int(x^2*exp(c(1)+c(2)*x+c(3)*x^2+c(4)*x^3),'x',0,1)-0.77161; En(4)=int(x^3*exp(c(1)+c(2)*x+c(3)*x^2+c(4)*x^3),'x',0,1)-0.67894; 调用程序如下: clear,clc; u=10*ones(4,1); c=fsolve(@fentropy,u) 运行二十分钟后出错: ??? The following error occurred converting from sym to double: Error using ==> sym.double at 25 DOUBLE cannot convert the input expression into a double array. If the input expression contains a symbolic variable, use the VPA function instead. Error in ==> fentropy at 5 En(1)=int(exp(c(1)+c(2)*x+c(3)*x^2+c(4)*x^3),'x',0,1)-1; Error in ==> trustnleqn at 225 F = feval(funfcn{3},x,varargin{:}); Error in ==> fsolve at 297 [x,FVAL,JACOB,EXITFLAG,OUTPUT,msg]=... Error in ==> maxentropy at 3 c=fsolve(@fentropy,u) 请教各路武林高手,带积分(积分后没有确定表达式)的方程组求解, 有没有更好的编程方法?当方程增至五、六时,计算量非常大,如何处理? 望赐教!!! |
#2 | |
怎么看不到图片啊?11111111
