旧 2007-12-11, 21:54   #1
liujie31
注册日期: 2007-12-11
liujie31 正向着好的方向发展
默认 【求助】求助matlab高手
求助matlab高手,请问下面两个语句分别是什么意思?请一一指出,非常感谢
options = optimset('Display','iter','Jacobian','off');%,...
%'LargeScale','on','PrecondBandWidth',1);
[x_1,fval,exitflag1,output]=fsolve(@(x0_1) twolay_EL(x0_1,a_0,L_nm1,...
M_y1,E_b,p_0,N,E_a),pstart1,options);
exitflag1
其中:twolay_EL(x0_1,a_0,L_nm1,...
M_y1,E_b,p_0,N,E_a)是解微分方程的,x0_1为变量
liujie31 当前离线   回复时引用此帖
旧 2007-12-13, 12:38   #2
xuxu119
注册日期: 2007-12-13
xuxu119 正向着好的方向发展
%this is a function(options) which has four inputs( Display,iter,jacobian,off),
%"Display" is a single parameter which determines the output direction or option
%"iter" defines the number of iterations the program which will run
%"jacobian" is just a simple matrix which is a reduction of the original equation sets, similar to Newton Rapson method
%"off" defines the state of the output, either 1 or 0
exitflag1
%"x_1,fval,exitflag1,output" are all output parameters,
%"fsolve" is the function name
%"@(x0_1) twolay_EL(x0_1,a_0,L_nm1,...M_y1,E_b,p_0,N,E_a),pstart1,options" is another function which evaluates the parameters. "@" means it handles the input values directly rather than substituing the values into the function in other scripts.
%"exitflag1" is the default flag which allows the user to adjust.
i hope this helps
xuxu119 当前离线   回复时引用此帖
旧 2007-12-13, 15:48   #3
liujie31
注册日期: 2007-12-11
liujie31 正向着好的方向发展
非常感谢这个大侠,谢谢你详细的回答。
请问Jacobian是怎么具体作用的?谢谢!
很崇拜你
所有时间均为北京时间。现在的时间是 18:09
