旧 2009-04-25, 10:54   #1
fangfang0l
注册日期: 2009-04-25
fangfang0l 正向着好的方向发展
默认 一道MATLAB题请问这个少了什么
一道MATLAB题 请问这个少了什么
设输入信号为 x(t)=Acsin2Лt,对x(t)信号进行抽样、量化和A律PCM编码,经过传输后,接收端进行PCM译码。
画出经过PCM编码、译码后的波形与未编码波形;
设信道没有误码,画出不同Ac情况下,PCM译码后的量化信噪比。
解:仿真的系统框图如图所示。
图为A律PCM量化器的动态范围仿真框图
%show the pcm encode and decode
clear all;
close all;
t = 0:0.01:10;
vm1 = -70:1:0; %输入的正弦信号幅度不同
vm = 10.^(vm1/20);
figure(1)
for k = 1:length(vm)
for m = 1:2
x = vm (k)*sin(2*pi*t+2*pi*rand(1));
v = 1;
xx = x/v;%normalize
sxx = floor(xx*4096);
y = pcm_encode(sxx);
yy = pcm_decode(y,v);
nq(m) = sum((x-yy).*(x-yy))/length(x);
sq(m) = mean(yy.^2);
snr(m) = (sq(m)/nq(m));
drawnow
subplot(211)
plot(t,x);
title('sample sequence');
subplot(212)
plot(t,yy)
title('pcm decode sequence');
snrq(k)=10*log10(mean(snr));
figure(2)
plot(vm1,snrq);
grid;
function [out]=pcm_encode(x)
%x encode to pcm code
n=length(x);
%-4096<x<4096
for i = 1:n
if x(i)>0
out(i,1)=1;
out(i,1)=0;
if abs (x(i))> = 0 & abs(x(i))<32
out(i,2)=0;out(i,3)=0;out(i,4)=0;step=2;st=0;
elseif32<=abs(x(i))&abs(x(i))<64
out(i,2)=0;out(i,3)=0;out(i,4)=1;step=2;st=32;
elseif64<=abs(x(i))&abs(x(i))<128
out(i,2)=0;out(i,3)=1;out(i,4)=0;step=4;st=64;
elseif128<=abs(x(i))&abs(x(i))<256
out(i,2)=0;out(i,3)=1;out(i,4)=1;step=8;st=128
elseif256<=abs(x(i))&abs(x(i))<512
out(i,2)=1;out(i,3)=0;out(i,4)=0;step=16;st=256;
elseif512<=abs(x(i))&abs(x(i))<1024
out(i,2)=1;out(i,3)=0;out(i,4)=1;step=32;st=512;
elseif1024<=abs(x(i))&abs(x(i))<2048
out(i,2)=1;out(i,3)=1;out(i,4)=0;step=64;st=1024;
elseif2048<=abs(x(i))&abs(x(i))<4096
out(i,2)=1;out(i,3)=1;out(i,4)=1;step=128;st=2048;
if(abs(x(i))&abs(x(i)))<4096
out(I,2:8)=[1 1 1 1 1 1 1];
tmp=floor((abs(x(i))-st)/step);
t=dec2bin(tmp,4)-48;%函数dec2bin输出的是ASCII字符串,48对应0
out(i,5:8)=t(1:4);
out=reshape(out',1,8*n);
function[out]= pcm_decode(in,v)
%decode the input pcm code
%in : input the pcm code 8 bits sample
%v:quantized level
n=length(in);
in=reshape(in',8,n/8)';
slot(1)=0;
slot(2)=32;
slot(3)=64;
slot(4)=128;
slot(5)=256;
slot(6)=512;
slot(7)=1024;
slot(8)=2048;
step(1)=2;
step(2)=2;
step(3)=4;
step(4)=8;
step(5)=16;
step(6)=32;
step(7)=64;
step(8)=128;
for i=1:n/8
ss=2*in(i,1)-1;
tmp = in(i,2)*4+in(i,3)*2+in(i,4)+1;
st = slot(tmp);
dt = (in(i,5)*8+in(i,6)*4+in(i,7)*2+in(i,8))*step(tmp)+0.5*step(tmp);
out(i)=ss*(st+dt)/4096*v;
fangfang0l 当前离线   回复时引用此帖
旧 2009-04-26, 05:59   #2
silas_xue
声望力: 26
silas_xue 是一个将要出名的人
默认 回复: 一道MATLAB题请问这个少了什么
lz 没有理解你的意思? 你指的是什么? 代码少了? 还是操作少了?
能否说的清楚一些 大家一起讨论一下
silas_xue 当前离线   回复时引用此帖
旧 2009-04-26, 10:00   #3
fangfang0l
注册日期: 2009-04-25
我问过老师 他说还少个程序,但我看不出来少什么,那里少,请各位高手帮我看看
旧 2009-04-26, 20:39   #4
bamboo
注册日期: 2009-04-20
bamboo 正向着好的方向发展
不好意思 我也是提问 的!
a=[1 2 3]
for i=1:3
b=abs(a(i))
这段程序为什么保存在m文件中不能运行啊!
bamboo 当前离线   回复时引用此帖
旧 2009-04-26, 20:39   #5
bamboo
注册日期: 2009-04-20
bamboo 正向着好的方向发展
请问在那里发表新帖?
thanks
bamboo 当前离线   回复时引用此帖
旧 2009-04-27, 04:19   #6
silas_xue
声望力: 26
silas_xue 是一个将要出名的人
lz 请把你的框图贴出来可以么?
我再看一下 谢谢
旧 2009-04-27, 04:23   #7
silas_xue
声望力: 26
silas_xue 是一个将要出名的人
2楼及3楼 根据问题的性质 在各区页面的左下角有“发表新主题” 点击后 完成你发的主题
Thx for reading.
个人观点 仅供参考 多多交流 相互学习
所有时间均为北京时间。现在的时间是 22:27
