旧 2009-03-05, 07:13   #1
roshan
注册日期: 2009-02-03
roshan 正向着好的方向发展
问题 [求助]Planetary Motion(行星运动)求助高手!
万有引力公式:F=Gm1m2/d12^2
现在有若干个星球在太空中由于引力相互作用,但是我的代码显示出来的若干个星球只能沿一个方向作直线运动,而不是相互环绕运行。如何才能让他们正确运行,请教各位大侠指教,等待指点迷津。万分感谢。
———————————————————题目大意:————————————————————————
the motion of bodies in 2-d space is to be investigated. the bodies
together constitute a small universe, and as such they both create and
are influenced by a gravitional field
Newton/Kepler demostrated that the total force Fi in the general case
of 50 masses is equal to
Fi=Gm1m2/d12^2+Gm1m3/d13^2+.......+Gm1m50/d150^2
create initial positions, velocities and displacement for 50 masse , display the motion graphically
when gets together,the force is big, the remidies include: place a
limit on max. force between masses. decrese the time step. set a
collision distance, when 2 masses are closer than this to each other,
they are assumed to collide, and become 1 body, with mass and momentum
equal to the sum of the pre-collision values.
———————————————————以下代码:————————————————————————
clear all;
close all;
G=6.67*10^-11;
% The universal gravitational constant
m = [1.989e30,3.5844e23,4.89868e24,5.974e24,6.5714e23,1.89854e27,5.68725e26,8.72204e25,1.02753e26];
% An array of masses
n = length(m); Number_of_planets = n
% The number of masses
x_p = [0,58340100000,1.07705e11,1.4959e11,2.27377e11,7.77868e11,1.42709e12,2.87512e12,4.49668e12];
% An array of x positions
y_p= [0,0,0,0,0,0,0,0,0];
% An array of y positions
x_v = [0,0,0,0,0,0,0,0,0];
% An array of x velocities
y_v = [0,47856.46,34961.72,29780,23883.56,12924.52,9618.94,6789.84,5419.96];
% An array of y velocities
T= 365*24*60*60;%(2*pi*G*m(1))/(x_v(1)^3);
dt=360*60*60*10;
colordef black;
ph = plot(x_p,y_p,'.','MarkerSize',30);
xlabel('distance(km)');
ylabel('distance(km)');
title('Planetary motion');
for a=0:dt:1000*T
%loop for all masses with respect to time
for k=1:n
%loop for individual masses calculating neccessary quantities
dx = x_p - x_p(k);
% difference in x positions
dy = y_p - y_p(k);
% difference in y positions
mag = (dx.^2 + dy.^2).^0.5;
% magnitude of the distance between the 2 masses
f = ((G*m(k)*m)./(mag.^2));
% total force
fx_old =(f.*dx./mag);
fx_old(k)= 0;
fx = sum (fx_old);
%Summing the total force in x direction for each planet
fy_old =(f.*dy./mag);
fy_old(k)= 0;
fy = sum (fy_old);
%Summing the total force in y direction for each planet
a_x = fx/m(k);
% calculating acceleration change in x direction
a_y = fy/m(k);
% calculating acceleration change in y direction
x_v(k) = x_v(k) + dt*a_x;
% calculating velocity change in x direction
y_v(k) = y_v(k) + dt*a_y;
% calculating velocity change in y direction
x_p_new(k)= x_p(k)+dt*x_v(k);
% calculating new x positions
y_p_new(k)= y_p(k)+dt*y_v(k);
% calculating new y positions
x_p=x_p_new;
y_p=y_p_new;
% overwriting old positions with new positions
pause(0.1)
axis([-(10^15) 10^15 -(10^15) 10^15])
drawnow
% Plotting graph
———————————————————华丽的分割线————————————————————————
拒绝签名!
roshan 当前离线   回复时引用此帖
旧 2009-03-05, 09:54   #2
lastmore
注册日期: 2009-03-03
lastmore 正向着好的方向发展
默认 回复: [求助]Planetary Motion(行星运动)求助高手!
代码我不看了,你确认一下你的加速度方向和速度方向是否不共线,其他应该很简单,不应该有问题!
lastmore 当前离线   回复时引用此帖
旧 2009-03-05, 11:52   #3
anbcjys
注册日期: 2008-09-14
anbcjys 正向着好的方向发展
作者: lastmore 查看帖子
确实 另外建议看看是否在初始位置
qq604443022
anbcjys 当前离线   回复时引用此帖
旧 2009-03-06, 01:54   #4
roshan
注册日期: 2009-02-03
roshan 正向着好的方向发展
Set a collision distance, when 2 masses are closer than this to each other,
_____________________________________________________________
还有,当两个运行的星球由于万有引力碰撞在一起后,就合二为一,这一步怎么做?
用到的动能公式:(m1+m2)v=m1v1+m2v2
拒绝签名!
roshan 当前离线   回复时引用此帖
旧 2009-03-06, 09:43   #5
anbcjys
注册日期: 2008-09-14
anbcjys 正向着好的方向发展
我的理解是 用这个动能公式来求碰撞后的速度的 这样生成一个新的速度
qq604443022
[求助]请问有做用matlab的hough算法检测遥感图像中的机场跑道的吗? ananjj MATLAB论坛 1 2009-04-06 01:29
发现MATLAB处理图像的不好的地方,跟大家讨论下 TT MATLAB论坛 4 2009-03-08 21:27
所有时间均为北京时间。现在的时间是 23:54
