#1 |
注册日期: 2008-03-02
声望力: 0 ![]() |
老板让做MATLAB的EXCEL的接口,最开始找到的就是EXCEL LINK。可是这个不能满足动态性。于是选择DDE,DDE的上手很简单,调用函数ddeinit, ddepoke都是ok的。可到了动态链接ddeadv,怎么也不行,查了整整半天的资料,一个老外也问同样的问题
I am facing problem in using ddeadv(function responsible for hot link between dde server and client) in newer version of matlab R2007a/b. Although I can init the communication, request and poke value to dde server but only ddeadv is not working. Please help me out. Sample code: channel=ddeinit('excel','m.xls'); working a=ddepoke(channel,'r1c1',5); working b=ddereq(channel,'r1c1'); working d=ddereq(channel,'r1c1','disp(x)','x') NOT WORKING; althout I am getting d=1 for that syntex but callback is not working, means when I change the value in the m.xls r1c1 the disp(x) function is not called . 没有人回答,原因只是用了7.1以上的版本! 同业的代码,同样用excel在6.5上就可以!! 有点无语了。浪费了一天的时间:cry: 最好大家讨论下其他的方法,要满足数据交换的动态性。既EXCEL改变一个数,在MATLAB中要相应的改变。谢谢大家! |
主题工具 | |
显示模式 | |
主题 | 主题作者 | 版面 | 回复 | 最后发表 |
有哪位做过BEESSEL法数字下变频? | yqgame365 | MATLAB论坛 | 0 | 2008-12-07 23:53 |
[讨论]已知各节点的水面高程做视频? | shxshd | MATLAB论坛 | 0 | 2008-11-25 23:44 |
GM(1,1) | lvlianggan | MATLAB论坛 | 2 | 2008-11-07 22:52 |
Simplify Instrument Communication: Using Instrument Drivers with the Instrument Contr | TechnicalArticles | MATLAB技术文章 | 0 | 2008-01-06 16:32 |
