#1 |
注册日期: 2009-01-03
声望力: 0 ![]() |
问题是这样的:
![]() 俺编的程序是这样,请问各位大侠可行否? function F=force(H,ro1,ro2,mu,tau,h0,Gv,lambda) global rho1 rho2 mu tau g h0 Gv lambda; F=81.2*(rho1*mu*tau^3)^(1/2)*a^3-4/3*pi*a^3*g*(rho2-rho1)+2*pi*h0^2*Gv*a/((H+1)*a)*(1+5.32*(H+1)*a/lambda)^(-1) % F: the net force on particle. crossflow lift=81.2*(ro1*mu*tau^3)^(1/2)*a^3, Gravity=4/3*pi*a^3*g*(ro2-ro1), van der Waals=2*pi*h0^2*Gv*a/((H+1)*a)*(1+5.32*(H+1)*a/lambda)^(-1) % rho1: the density of water % rho2: the particle density % mu: the solution viscosity % tau: the wall shear rate % g: the gravitation constant % h0: the minimun interfacial separation distance % Gv: van der Waals interfacial free energy % lambda: characteristic decay length for van der Waals % H: the dimentionless distance from particle to the surface of membrane. H=z/a-1 %(z is the vertical distance from particle to surface of membrane) end function f=f1(H) f=sqrt(sin((H+1)*a))/(((quad('sqrt(sin((H+1)*a))',0,((H+1)*a))))^(1/3)) % f1(H): the universal function to account for hydrodynamice interaction according to Smoluchowski-Levich approximation. end function funb1=B1(H) funb1=diff(log(f1(H)),H)-F(H) end function funb2=B2(H) funb2=F(H)*(diff(log(f1(H))),H)-(diff(F(H),H))/f1(H) end function Con=Con-Frofile(H,y) % the DE y'' + B1(H)y’ + B2(H)y = 0 written as a system. % y is the concentration profile of particle dependent on H. Con(1)=y(2); Con(2)=-B1(H)*y(2)-B2(H)*y(1); f=f( ![]() return % trying to solve y''+ B1(H)y'+ B2(H)y = 0 at y(0)=0 y(2B/a-2)=0 clear all c=1; % the first guess for y'(0) Hu=2B/a-2; % the top of flow cell global B; % the half hight of flow cell tspan=[0 Hu]; while c > -999 % loop through different c values c=input('enter c, -1000 to stop'); if c==-1000 break; end % if c=-1000 jump out of loop y0=[0 c]; % initial condition [y(0) y'(0)] [H,y]=ode45('Con-Frofile',tspan,y0); plot(H,y(:,1)) % plot current solution hold on % keep the plot lgthy=length(y); % find the length of the vector y disp([y(lgthy,1)]) % show y(H=Hu) value cc=num2str(c); % convert value of c to a string variable text(2.1,y(lgthy,1),cc) % write value of c on rhs of graph end text(2.1,5,'c guess') % write c guess on the plot at (2.1,5) hold off print -deps Con-Frofile |
主题工具 | |
显示模式 | |
主题 | 主题作者 | 版面 | 回复 | 最后发表 |
[资料]BP网络总结及应用实例 | guofeng0108 | MATLAB论坛 | 37 | 2012-06-11 22:08 |
[求助]The input character is not valid in MATLAB statements or expressions. | mumu | MATLAB论坛 | 2 | 2008-11-26 12:58 |
[求助]电力系统机组启停优化算法程序 | woshi523de | MATLAB论坛 | 1 | 2008-11-18 08:12 |
[求助]请问这种图怎么画 | yape14 | MATLAB论坛 | 4 | 2008-09-22 09:04 |
