[求助]关于xilinx生成代码的问题
我前几天安装的ISE,试图应用simulink搭建的框图产生verilog代码,但是在产生代码的过程中总会报错,(后来我用别人可以生成代码的的框图运行,还是同样错误),我觉得这不是框图问题,但是软件安装过程中没有什么问题,大家有谁遇到过这种问题没,期待指教,交流。
错误大概是这样的,说产生代码过程(在网表产生时出错)出现异常,特别指出是XNetlistEngine。com.xilinx.sysgen.netlist.f:不能运行(Couldn't run)。 上面的是我翻译过来的报错信息,具体如下: Begin generation Checking model status Checking simulation times Performing compilation and generation *** ERROR *** Errors occurred during netlist generation. Error using ==> sim Error reported by S-function 'sysgen' in 'add_text/Gateway In': Summary of errors from all sources: (NOTE: None of the errors were associated with a particular block; the block reporting this summary was chosen at random.) -------------------------------------------------------------------------- Summary of Errors: Error 0001: caught standard exception Block: Unspecified -------------------------------------------------------------------------- Error 0001: Reported by: Unspecified Details: standard exception: XNetlistEngine: An exception was raised: com.xilinx.sysgen.netlist.f: couldn't run c:\Xilinx/bin/nt/coregen -b makeproj at D:/MATLAB/R2006a/toolbox/xilinx/sysgen/scripts/SgGenerateCores.pm line 721. --------------------------------------------------------------------------. 大家帮我分析下是哪里出的错,应该怎么解决才好,如果恰好遇到过这种问题,希望能说下具体的解决方案,谢谢。 (我的QQ:360984745 小周) |
所有时间均为北京时间。现在的时间是 16:49。 |
