[讨论]用二分法求函数根的程序
各位好!我正练习用matlab做数值计算,我从书上抄了一个用二分法求函数根的程序,但不知老师提醒我输入函数无效请问该怎么弄?源程序如下:
function [c,err,yc]=bisect(f,a,b,delta) %Input -f is the function input as a string 'f' % -a and b are the left and right end points % -delta is the tolerance %-Output -c is the zero % -yc=f(c) % -err is the error estimate for c ya=feval(f,a); yb=feval(f,b); if ya*yb>0,return,end max1=1+round((log(b-a)-log(delta))/log(2)); for k=1:max1 c=(a+b)/2; yc=feval(f,c); if yc==0 a=c; b=c; elseif yb*yc>0 b=c; yb=yc; else a=c; ya=yc; end if b-a<delta,break,end end c=(a+b)/2; err=abs(b-a); yc=feval(f,c); 我在命令窗口输入:bisect('x^3-2*x+2',-10,10,0.001) 结果显示 ??? Invalid function name 'x^3-2*x+2'. Error in ==> bisect at 8 ya=feval(f,a); |
回复: [讨论]用二分法求函数根的程序
改成这样
f = @(x)x^3-2*x^2+2; >> bisect(f,-10,10,0.001) 即可 |
| 所有时间均为北京时间。现在的时间是 12:54。 |
