[求助]请教matlab启动后当前目录的永久更改问题
如何永久改变matlab启动后的当前工作目录?Matlab默认的current directory是
C:\Documents and Settings\username\My Documents\MATLAB 虽然可以启动后更改,但关闭后再启动有变成这个目录。应为我的工作目录设置在别的盘, 每次启动后更改很麻烦,所以请高手赐教,多谢! |
回复: [求助]请教matlab启动后当前目录的永久更改问题
1. In Matlab
Matlab help search: Startup Directory for MATLAB 2. Changing the Startup Directory You can start MATLAB in a directory other than the default. For Windows Platforms Only. To change the startup directory on Windows platforms, I. Right-click the MATLAB shortcut icon and select Properties from the context menu. The Properties dialog box for matlab.exe opens to the Shortcut page. II. Enter the new startup directory in the Start in field and click OK. The next time you start MATLAB using that shortcut icon, the current directory will be the one you specified in step 2. |
cool,就是这样做
所有时间均为北京时间。现在的时间是 16:52。 |
