关于for循环得问题。急!!
更改一下,为了方便,我把源代码附上:
N=input('\N Enter the amount of nodes:N='); M=input('\M Enter the amount of lines:M='); B1=input('\B1 Enter the details of transmation line:B1='); %first column stands for one termination %second column stands for the other termination %third column stands for the impendance of transmation line %fourth column stands for the admittance between transmation line and %ground %fifth column stands for the ratio of transformer k %on the sixth column, '1' represents P is on the high-voltage side;'0' %represents P is on the low-voltage side X=input('\X Enter the number of node and the impedance between them:X='); %h=input('\h Enter the harmonics:h='); Y1=zeros(N); %***********set up harmonic frequency**********% h1=[];h2=[]; for n=0:3 if n==0 h1=[h1,6*n+1]; else h1=[h1,6*n+1]; h2=[h2,6*n-1]; end end h3=[h1,h2]; k=sort(h3); %***********************************************% for a=1:7 %**********the main 'for loop' for the total calculation**********% %**********Y-MATRIX**********% for i=1:N if X(i,2)~=0; p=X(i,1); Y1(p,p)=1./X(i,2); end end for i=1:M if B1(i,6)==0 p=B1(i,1);q=B1(i,2); else p=B1(i,2);q=B1(i,1); end Y1(p,q)=Y1(p,q)-1./(B1(i,3)*B1(i,5)); Y1(q,p)=Y1(p,q); Y1(q,q)=Y1(q,q)+1./(B1(i,3)*B1(i,5)^2)+B1(i,4)./2; Y1(p,p)=Y1(p,p)+1./B1(i,3)+B1(i,4)./2; end G=real(Y1);B0=imag(Y1); Y=G+j*k(1,a)*B0; B=imag(Y); disp('The Y-matrix is:'); disp(Y); disp('G is:'); disp(G); disp('B is:'); disp(B); disp(k(1,a)); a=a+1; end 输入变量为:N=5;M=5;B1=[1 2 0.105i 0 1.05 0; 2 3 0.024+0.065i 0.032i 1 0; 2 4 0.03+0.08i 0.04i 1 0; 3 4 0.018+0.05i 0.026i 1 0; 4 5 0.184i 0 0.96 1]; X=[1 0;2 0;3 0;4 0;5 0] 想得到得理想结果是:G一直不变;B值为k倍(k=1,5,7,11,13,17,19) 结果按照这个程序得到得结果为:G随a倍递增,B值没有找到规律。 想请各位帮帮忙!十分感谢!在线等~~ |
所有时间均为北京时间。现在的时间是 14:27。 |
